The Whirlwind I computer (1951) was the first computer with CRT graphics, a lightgun and magnetic core memory. It was designed and used for real-time, interactive use with more than one CRT!
For showing a Whirlwind programme's output on a real CRT with all the flicker and blur, a small hardware generates vector strokes on X/Y/Z CRT (scope) screens and allows to attach light guns.
Guy Fedorkow's WWI simulator running on a Raspberry Pi can drive the interface and run some original WWI programmes with more than one displays.
The resolution is 1024x1024 monochrom pixel, as of the original. A display like the TEK 611 is required to enjoy the full resolution.
Design documents including KiCad EDA files are free and open source, currently available vie GitHub.
The interface is distributed to a master interface that connects to the RASPI and one or more tap boards, one for each CRT display. There is a tap board that can drive scopes which need higher voltages (>10V) on the Z input
Files
WWI_VectorIF.pdf
Technical documentation of the hardware.
Adobe Portable Document Format -
49.62 kB -
10/26/2026 at 14:20
