In the second case,the super precision gyroscope was fitted to the hand of the same person and the results were observed.
As you can see from the graph the vibration of the hand was considerably reduced as suggested by the frequency in the graph.The main problem was the weight of the super-precision gyroscope which interrupts the old people in their daily activities even though it reduces the vibration when the hand is idle.
The gloves also consists of an emergency button as it is going to be mostly used in old age people,which is used to alert others in case of any danger.
