A left/right control with a center press can cover a surprising amount of a small interface: move between choices, adjust a value, then select it. This breakout exposes those actions without requiring a keypad.
The common C terminal connects to ground. With pull-ups enabled on the host GPIO inputs, moving left or right pulls output 1 or 2 low, while pressing pulls T low.
The wiring stays simple and the behavior stays in your firmware. A menu, a jog control or a display-mode selector can use the same physical input arrangement.
Key specifications:
• C common terminal
• T push output
• 1 left output
• 2 right output
• Use GPIO input pull-ups
Product documentation: https://www.questwiseventures.com/products/3-way-left-right-toggle-and-push-button-breakout
Michael Yim
