Bone Conductor Headphone Speaker Breakout Board
A bone-conduction speaker breakout for experimenting with vibration-based audio output.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This breakout lets you experiment with sound as a physical vibration. A bone-conduction transducer couples vibration through contact, offering a different interaction from a small speaker playing into the air.
The board combines the actuator with a 3.5mm audio jack and 2.54mm headers for alternative audio connections. Two M2 mounting holes provide a way to incorporate it into an experimental enclosure or fixture.
Documentation: https://www.questwiseventures.com/products/bone-conductor-headphone-speaker-breakout-board
