Hackaday.io Hackaday.io
Sign up Log in
GinLab - [20700]
Projects/Users/Experiments - Acquire ⨋ Analyse ⨋ Share
gintaras-valatkaGintaras Valatka
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
906
0
4
3
Team (1)
  • gintaras-valatkaGintaras Valatka
Join this project's team
Software
ongoing project
ginscope aquisition data serial projects log test measure Experiment reproducable oscilloscope lut firmata adrduino control led LDR remote Relay lab sci toolbox calculator fft frequncy domain polot graph export share
This project was created on 03/27/2017 and last updated 9 years ago.
Description
GinLab = UI/UX/Acquisition/Analysis/Plotting
Projects/Users/Experiments -> Program ∑ Control ∑ Run ∑ Acquire ∑ Save ∑Analyse ∑ Share
GinLab = GinScope: https://hackaday.io/project/19374-ginscope
GinLab = GinLogic: https://hackaday.io/project/26161-ginlogic
GinLab = GinGen: https://hackaday.io/project/19836-gingen
Use cases:
Studies
Experiments
Benchmarking
Plotting time/freq Doamin etc
Matching parts - electronics
Generating LUTs + more
Control:
Midi, Joystick, Light, Sound, various sensors etc
Project Logs
Collapse
  • Controlling ⨋ Firmata
    Gintaras Valatka • 07/15/2017 at 11:48 • 0 comments
    Switching relays between AC & DC, single ended & differential inputs. vRef controlled by RGB LED coupled to LDR (light dependant resistor) in dark layers of heat shrink tube controlled by PWM making it a Variable Resistor. Voltmeter is built with another Arduino ADC 0-5V. The RGB LED at the bottom right is mirroring hidden LED (vRef is not calibrated)
    All from the browser! Switching relays between AC & DC, single ended & differential inputs. vRef controlled by RGB LED coupled to LDR (light dependant resistor) in dark layers of heat shrink tube controlled by PWM making it a Variable Resistor. Voltmeter is built with another Arduino ADC 0-5V. The RGB LED at the bottom right is mirroring hidden LED (vRef is not calibrated)
    On Arduino can also control AREF pin, used by analogRead(), by externally setting vRef and in the sketch setting analog reference to EXTERNAL, if using Arduino ADCs https://www.arduino.cc/en/Reference/AnalogReference
    Home made Variable Resistor @ https://hackaday.io/project/21480-ldr-pot-making-matching-plotting
  • Logging VICHY VC99
    Gintaras Valatka • 05/03/2017 at 20:31 • 0 comments
    This will plug into GinLab. There will be ability to log, analyse, export etc
    https://hackaday.io/project/21300-vichy-vc99-going-bluetoo-forget-optical-separation
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
I made an RGB pumpkin wall light, which can be controlled by a smartphone via Bluetooth, it has different modes and different colors so you
Project Owner Contributor
Bluetooth Controlled RGB LED Lamp
vishal-sonivishal soni
This fun diy project utilizes Arduino Nano and addressable LED strip to create custom cool light show.
Hoverboard Digital LED Lighting
martinMartin
RGB LEDs are used everywhere, in many different products and devices. This Arduino library is to the control of RGB LED's
RGB_LED Library
tinkers-projectsTinkers Projects
LED strip fades in when somebody is doing something at the kitchen cupboard.
Auto-fading LED strip for kitchen
brigadirbrigadir
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "GinLab - [20700]", please tell us the reason.
Send message
Remove Member
