E660 6-Digit Electro-mechanical Counter
A six-digit electromechanical counter with a 5V breakout and falling-edge count input.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A mechanical count has a different presence from numbers on a screen. The E660 advances physical digits, making it an interesting output for event counters, interactive exhibits or a visible tally.
The interface accepts 5V and uses an onboard step-up converter to supply the counter’s 24V drive. Each falling edge on CNT advances the six-digit count by one.
It counts upward only and requires at least 20ms between pulses. Those constraints matter when mapping an encoder or sensor to the display: the host must turn a requested increment into suitably spaced pulses.
More product information: https://www.questwiseventures.com/products/e660-6-digit-electro-mechanical-counter
