Electromechanical Status Indicator Breakout Board
A red/green electromechanical status indicator that retains its displayed state when power is removed.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A status indicator does not always need to glow. This electromechanical module physically switches between red and green and holds the visible state when power is removed.
The change comes with a mechanical click, giving the transition a small audible cue as well as a visual one. That makes it an interesting choice for a persistent status flag or interactive control panel.
The important distinction is that the displayed state can outlast the power supply. A project using it should decide what that retained state means after a restart, rather than assuming it always describes the current live system.
Documentation: https://www.questwiseventures.com/products/electromechanical-status-indicator-breakout-board
