Energy-Harvesting Wireless Transmitter & Receiver
A button-powered wireless transmitter paired with a receiver providing pulse and toggle outputs.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A wireless button is easier to place when its transmitter does not need a battery. Here, pressing the button supplies the energy: a spring mechanism transfers the motion to a coil, briefly powering the transmission.
The receiver still needs a 3.3V supply. It exposes both a PLS output that pulses for a press and a TOG output that changes and holds its logic state until the next press.
Those two outputs suit different interactions, such as waking a controller or toggling a function. A demonstration test shows operation over a couple of meters.
Documentation: https://www.questwiseventures.com/products/energy-harvesting-wireless-transmitter-receiver
