ESP-12F WiFi Remote Door / Cabinet Lock Dev Board
An ESP-12F WiFi development board integrated with a cabinet-lock mechanism and USB programming.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This board brings a Wi-Fi controller and a physical latch into the same prototype. An ESP-12F controls the lock through GPIO5, while an onboard converter supplies the mechanism's 12V drive from a 5V USB input.
A genuine FTDI USB interface supports programming with the ESP8266 Arduino core. Holding Flash during power-up enters programming mode, making the assembly accessible for experimenting with control firmware.
The demo uses a phone connected to the board's web server to operate the latch. That is a useful starting point for a cabinet-control experiment; authentication, network exposure and failure behavior still need deliberate design before relying on it for security.
Documentation: https://www.questwiseventures.com/products/esp-12f-wifi-remote-door-cabinet-lock-dev-board
