ESP32 SPI Color 8-Pin TFT Evaluation Board Bundle
An ESP32-based SPI evaluation board bundled with four interchangeable color TFT displays.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Choosing a display from dimensions alone can be misleading. This evaluation bundle lets you try four different TFT sizes and shapes on an ESP32-based board before committing to an enclosure or user interface.
The displays share an eight-pin SPI connection, reducing repeated wiring during comparison. The bundle includes a 0.99-inch GC9107 panel and 1.14-, 1.47- and 2.01-inch ST7789 panels, with different resolutions and aspect ratios.
Use the Arduino GFX library linked in the product documentation to test how real text, icons and layouts fit each panel. The point is to make the display decision with something working in your hand, rather than just a list of pixel counts.
Documentation: https://www.questwiseventures.com/products/esp32-spi-color-8-pin-tft-evaluation-board-bundle
