Sometimes a small project needs a softly lit area rather than a point of light. FlexiGlow is a flexible white backlight panel intended to spread illumination across a thin surface.
The panel measures 29 × 36 × 0.85mm and comes with a small breakout offering header or castellated connections. VIN and GND provide a simple interface, with approximately 3V input and PWM brightness adjustment.
That form suits experimenting behind a translucent graphic, inside a miniature light panel or as part of an illuminated object. It supplies the lighting layer, so the material placed in front of it becomes part of the final visual design.
