Firmware uploaded.
A project log for OpenESpin
Building an Electrospinning machine for everyone.
douglas-millerDouglas Miller 07/26/2017 at 00:070 Comments
I finally have the firmware for the machine cleaned up enough (I hope!) and uploaded. You can find it in the projects file list.
I also stuck in the beginnings of an operations manual. It has the list of commands to run the machine in it. It's in the same ZIP file as the firmware. The operations manual is a bit lean, but I'll be adding to it as time goes on.
Rich text editor
