Sharp 1.26-inch 144x168 Memory LCD Breakout
A Sharp LS013B7DH07 reflective monochrome memory-LCD breakout with a 144×168 pixel array.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This breakout pairs a Sharp LS013B7DH07 memory LCD with accessible connections for a compact reflective interface. Its 1.26-inch panel has 144×168 monochrome pixels and uses ambient light rather than a backlight.
A controller sends data over the three-wire SPI interface, with 3.3V power and display-enable connections available on the board. The reflective panel is suited to experiments with daylight-readable interfaces; power consumption depends on the actual driving conditions.
Product: https://www.questwiseventures.com/products/sharp-1-26-ultra-low-power-1ua-144x168-memory-lcd
