One of my main goals from the start was to make the project accessible to anyone with an off-the-shelf Raspberry Pico. The RP2040/RP2350 controllers will function perfectly well as a simple oscilloscope and logic analyzer. But these boards lack protection and work only at 3.3V. To enable the full feature-set and add some robustness, I designed a custom PCB.
For the microcontroller, I selected the RP2350B, which offers more GPIO in a 48-pin package as well as 8 ADC channels vs the 4 channels on the more common RP2350A. Half the ADCs will be used for the oscilloscope, the others for current and voltage monitoring. To make analog measurements more accurate, I added a voltage reference (LM4040) to the VRef input. The Picos usually need a button to configure them for the USB bootloader mode. I included a 90° tactile switch on the board edge for this purpose. The button is also wired to a GPIO pin, so it can be used by the firmware at runtime.
I really like the Nordic PPK2 for its software-adjustable output voltage and wanted to implement a similar feature for my project. The PPK2’s regulator works by combining an efficient buck-boost regulator with a low-noise LDO. Both are controlled by injecting analog control voltages into their feedback loops. While this works beautifully, the part count and overall complexity had me looking for easier solutions. This led me to the MPS MP28167-A, a buck-boost converter mainly designed for USB-PD applications. Instead of having to manipulate its reference voltage externally, it is fully controlled via I2C. The output voltage can be set in 0.8mV increments from around 1V to 5V, and even the current limit can be configured. Another great thing is that it decouples the voltage regulation completely from the Pico. Even a firmware reboot or crash won’t throw off the regulator’s voltage. It also only needs a few external components:
The MP28167 has no ability to read the actual output voltage and current from its registers, so I added a simple voltage divider and a current-sense amplifier. These are wired straight to the RP2350’s ADCs. Because there were 2 ADC channels left, I also added current sensing for the 3.3V and 5V output rails. This will be nowhere near as accurate as the PPK2’s auto-ranging current measurement, but it’s good enough to determine if, e.g., an RF module is working correctly. In addition, an ideal diode (LM66100) protects all output rails from reverse current.
In addition to the 4 analog channels, the device has 8 digital GPIOs. These are used for the logic analyzer feature, as well as for directly controlling inputs and outputs. To make these GPIOs compatible with a range of target voltages, a level shifter is needed. I chose the SN74LVC1T45DBV because it has some nice protection features and is also used in the latest Bus Pirate boards. One side of this buffer is supplied by 3.3V, and the other by an external target voltage between 1.2V and 5V. One extra pin per buffer sets the direction (input/output). I also added a switchable pull-up resistor to each port. I was not sure if I could implement bus decoders in software, so I opted to include UART, SPI, and I2C on dedicated pins. They use the same circuit as the GPIO ports, but without the switchable pull-up and with fixed directions. Because I2C needs open-drain signals and I was too lazy to implement bit-banged I2C for the SN74 like the Bus Pirate does, I included a specialized level shifter: the PI4ULS5V202.
With a total of 16 digital channels, the component count on the board is quite high. I tried arranging everything as compactly as possible on a 4-layer PCB. On one edge of the board, I placed four rows of 4x2 pin headers for plugging in breadboard wires. The USB port and boot button are placed on the side edges. An SK6812MINI RGB LED serves as a status indicator. By adding a diode to its VCC input, it comfortably works with the 3.3V logic voltage and 5V supply.
I ordered the PCBs from JLCPCB and assembled them by hand. After assembling 5 of these, I am seriously considering getting a pick-and-place machine to save my sanity.
Max.K
