Time Warp Studio: A native C++20/Qt6 retro IDE with 10 built-in interpreters, universal debugger, turtle canvas, and 2 virtual machines.
chmod +x Time_Warp_Studio-x86_64.AppImage ./Time_Warp_Studio-x86_64.AppImage
.dmg file and drag Time Warp Studio to your Applications folder. (Note: You may need to right-click and select "Open" to bypass unsigned developer warnings).💻 Recommended Testing Protocol
Once inside the Borland/Turbo C++ inspired Text User Interface (TUI) and split-screen canvas layout:
1. Execute an Interactive Command (REPL)
PRINT "Hello from the parallel universe!"Use code with caution.
2. Run a Multi-Language Code Demo
Time Warp Studio sandboxes six classic educational languages. Go to File -> Open Examples and load a sample file: [1]
3. Step Through the Debugger
BASIC or Scheme template. [1]🛠️ Building from Source (Optional)
If you prefer to compile manually from the MIT-Licensed Repository: [1]
mkdir build && cd build cmake .. cmake --build .
