From the Github readme:
1.0 Introduction
This document describes the T-11/RP2350 project. The RP2350 serves memory and peripherals to the Digital Equipment Corp (DEC) Tiny-11 (DCT-310) single chip PDP-11. Currently, the board is able to boot and run RT-11 5.07.
1.1 Emulated system
Currently, the following devices are emulated:
- KW11 - line time clock, configurable as 50 or 60 Hz. An RP2350 timer provides the interval.
- DL11 - single line UART. RP2350 SDK used to send/receive characters to/from the T-11.
- RK11 - 2.5 MB disk drive. This is mapped to a file on a micro SD card, using the SDIO/FatFS libary.
- M9312 - console and boot ROM card. Slightly modified PDP-11 boot ROM and standard RK boot code storage is emulated.
1.1 Background
The T-11 as Digital's first single chip PDP-11, and was intended for commercial board designs. As such, it was used for DEC products such as the VT240 terminal and peripheral controllers. It saw limited commercial success, of which the Paperboy video arcade console is one example.
1.2 Motivation
I started with DEC right out of college, working for the Semiconductor Engineering Group in Hudson, MA. My first assignment was supporting the T-11, including design reviews, documentation, etc., so this project was a great way to re-visit that part of my career.
2.0 Design
The RP2350 is fast enough to provide full speed memory to the T-ll with the use of PIO and DMA. Currently, the design uses about 50 clocks to provide 8/16 bit memory reads and writes using four DMA channels and one PIO instance with it's four state machines. In addition to supporting memory, the other state machines provide interrupt cycle support, T-11 mode register loading, and forwarding of I/O requests to the RP2350 processor. The latter facility copies I/O page memory requests to a dedicated FIFO so that the RP2350 can be interrupted when I/O occurs.
2.1 I/O
When the T-11 performs a memory access to I/O space (the last 8KB), PIO and DMA performs a read or write to the RP2350 internal memory to complete the request. Simultaneously, another PIO engine pushes the address and data to a PIO FIFO so that the RP2350 can update the affected I/O locations. For instance, a T-11 read of the DL11 UART receive buffer must return the RX buffer, and also clear the RX ready flag. So, the PIO/DMA machine will return the emulated RX buffer contents, and I/O PIO machine will trigger the RP2350 service routine to clear the RX ready flag. (Of course, there is an implicit execution time limit: the flag must be cleared faster than the T-11 can read the next memory location). In general, simple side effects can be handled in a RP2350 interrupt service routine, while longer operations must be handled by an event loop running at normal priority. Emulation of disk drives is handled this way.
3.0) Getting started
3.1) Hardware
Gerbers are in brd/pico2-t11_rev_1.0.
Rev 1.0 requires the following ECOs:
- Disconnect GPIO 47 from T11 pin 36 (VEC) and connect to T11 pin 39 (HALT).
- Add 1k pullups resistors to: HALT (pin 39), PF (pin 38), and DMR (pin 32).
- Add 1k pulldown resistors to: VEC (pin 37), and BCLR (pin 18).
3.2) Software
As configured, the default is to load the boot block from the RK05 image on the SD card. There are defines for starting up test code in pdp11_src, or starting the emulated m9312 boot rom code.
3.2.1) Building
Some prerequisites:
- macro11, from https://github.com/simh/simtools.git
- obj2bin.pl, from https://github.com/AK6DN/obj2bin/blob/master/obj2bin.pl
Build steps:
- cd to sw/initial_test_v1.0
- Make a soft link to your installation of no-OS-FatFS-SD-SDIO-SPI-RPi-Pico.
- cmake -B build -S .
- make -C build -j
3.2.2 Booting RT-11
- Get an RK05 RT-11 disk image, copy to a micro SD card with a name of rk0.dsk, insert card into the microSD card slot on the board.
- make -C build -j
- Start open-ocd and load initial_test.elf onto the board
4.0) Techniques of interest:
4.1) PIO
- Use the PIO mov dest,~src to invert bits for easy logical testing. E.g. when determining if a bus operation was a read (0b11), or one of: write low byte, write high byte, or write word, inverting the control signals made this a test for zero (read), or write (everything else).
- Preload a register with a fixed value to avoid having to create it via PIO instructions.
- Use the wrap registers to jump in and out of other PIO engine code. This allows zero overhead code sharing. However, the same code must be loaded into the PIO state machines so that targets can be shared between them.
- Use IRQ flags to signal another PIO SM with different pin maps to support particular T11 transactions. E.g. the IACK transaction simultaneously reads the interrupt vector on DAL<7:2>, while acknowledging the interrupt on DAL<15:08>, thus requiring outputs only on the lower byte. To avoid extra PIO instructions for manipulating the direction register, we configure two SM instances: one with 16 bit DAL outputs, and one with 8 bits. Then, we can use mov pindirs, ~NULL to set output direction in both machines.
- Use out exec to enable the RP2350 to enable sharing of pins between PIO and C running on the RP2350.
- Use PC wrap from 31 to 0 to save a jump.
4.2) C code
- Use a table driven function lookup to collapse IO decodes into a fixed set of instructions. The first attempt at dispatching device emulators resulted in a maximum T-11 speed of 3.5 MHz, due to the amount of time needed to determine if the address was a device to be emulated or not. Converting the serial execution of successive compares to a table of functioned dispatched via the I/O address allowed the T-11 to operate at full speed. (Though a further, not yet fixed, bug in the disk emulation limits speed to 7.3 MHz).
- Use of the second core for capturing T-11 bus transactions is very helpful when debugging.
5.0 Adventures while developing
5.1 Turns out, emulating old systems is never easy
So the initial design did not support the Q-bus and Unibus Non-Exsitent Memory trap. T-11 doesn't have a built-in interrupt for this, and I thought that a system generation step could be used to remove unneeded I/O devices from RT-11. Unfortunately, after getting the board to load and run code from the emulated RK05, I couldn't get RT-11 to boot. After some debugging, I discovered that NXM is used to determine processor type, and without it, a processor that uses instructions that the T-11 doesn't have, is selected. So, used the HALT non-maskable interrupt to emulate NXM. It's not perfect, as the same interrupt vector is shared between the NMI and HALT instruction execution. Custom T-11 boot code attempts to distinguish between the two cases, but it's not perfect.
5.2 Still debugging this one
The RL emulation still has a bug: a race condition between the interrupt servicing the registers, and the main line code performing the actual disk operations. I'm not certain where the race conditions is, but better separation between the ISR's version of the command register and the main line's might be the solution. I'm also suspicious of the RK emulator, as it breaks when the T-11 is run at full speed. As far as I can tell, there's no hardware reason that prevents this.
5.3 It's still cool
Amazed when the OS actually booted! Here's the first boot log entry:
4-oct-2026: Thought about NXM generation: should only need to assert halt for reads, as writes are always preceeded by a read. Also, should count NXM services to make sure they match with generated requests. So, before eliminating write NXM RKDA: 000006 lba: 6 00000006 NXM: 5 RKDA: 000020 lba: 12 0000000c NXM: 5 RKDA: 000010 lba: 8 00000008 NXM: 5 RKDA: 000012 lba: 10 0000000a NXM: 5 RKDA: 010211 lba: 3177 00000c69 NXM: 5 RKDA: 000263 lba: 135 00000087 NXM: 5 RKDA: 000264 lba: 136 00000088 NXM: 5 RKDA: 000553 lba: 275 00000113 NXM: 5 RKDA: 010207 lba: 3175 00000c67 NXM: 5 Looks like we're not NXMing during either the read or the write portion of a write req. Let's try eliminating generating the write NXM req...works great: RKDA: 000006 lba: 6 00000006 NXM: 5 RKDA: 000020 lba: 12 0000000c NXM: 5 RKDA: 000010 lba: 8 00000008 NXM: 5 RKDA: 000012 lba: 10 0000000a NXM: 5 RKDA: 010211 lba: 3177 00000c69 NXM: 5 RKDA: 000263 lba: 135 00000087 NXM: 5 RKDA: 000264 lba: 136 00000088 NXM: 5 RKDA: 000553 lba: 275 00000113 NXM: 5 RKDA: 010207 lba: 3175 00000c67 And scope confirms only halt assertions for reads. Bottom line: 1) Halt assertions are captured during the reads of a T-11 write transaction. 2) T-11 write transactions are atomic: can't interrupt between the read and write operations that make up a T-11 write transaction. Note: Scope shows about 100ns from RAS rising to de-assertion of HALT request. Removing the wait for RAS rising edge removes the delay. So, it takes 100ns to detect and act upon an edge in C. Keep that in mind... Also, it takes 630ns to determine if NXM halt should be asserted or not. This is pretty much an entire RAS low time at 7.5 MHz, so we miss the de-assertion of RAS and keep halt asserted. Not good. Operating at 3.75 for now... Onwards. So, it looks like we're servicing interrupts, as we get a second disk command after enabling RK irqs: KDA: 000002 lba: 2 00000002 RKCS: 000004 RKDA: 000006 lba: 6 00000006 RKCS: 000004 RKDA: 000020 lba: 12 0000000c RKCS: 000004 RKDA: 000010 lba: 8 00000008 RKCS: 000004 RKDA: 000012 lba: 10 0000000a RKCS: 000004 RKDA: 010211 lba: 3177 00000c69 RKCS: 000004 RKDA: 000263 lba: 135 00000087 RKCS: 000004 RKDA: 000264 lba: 136 00000088 RKCS: 000004 RKDA: 000553 lba: 275 00000113 RKCS: 000104 RKDA: 010207 lba: 3175 00000c67 RKCS: 000104 Let's look at the TT CSRs: RKDA: 010207 lba: 3175 00000c67 StStStStStStStStStStStStStStStStStStStStStStStStRRRRrStrStrStrStStrStStrStStStSt StrStStrStrStrrrrrrrStStStStRKDA: 000062 lba: 38 00000026 RKDA: 000264 lba: 136 00000088 RRRRRKDA: 000340 lba: 168 000000a8 RKDA: 000402 lba: 194 000000c2 RKDA: 000006 lba: 6 00000006 RKDA: 000020 lba: 12 0000000c RKDA: 000010 lba: 8 00000008 RKDA: 004325 lba: 1697 000006a1 StStStStStStStStStStStStStStRKDA: 000346 lba: 174 000000ae StStStStStStStStStStStStStStStStStStStStRKDA: 000364 lba: 184 000000b8 RKDA: 000006 lba: 6 00000006 RKDA: 000566 lba: 282 0000011a RRRKDA: 000567 lba: 283 0000011b RKDA: 000600 lba: 288 00000120 RKDA: 010207 lba: 3175 00000c67 RKDA: 010210 lba: 3176 00000c68 RKDA: 000605 lba: 293 00000125 RKDA: 000620 lba: 300 0000012c RKDA: 000006 lba: 6 00000006 RKDA: 000020 lba: 12 0000000c RKDA: 000010 lba: 8 00000008 RKDA: 004327 lba: 1699 000006a3 So that's interesting: when we bang on the kb, interesting things happen. So, thought about this for a bit. Realized that we hadn't quite emulated correct TX IE enable behavior: viz - if the interrupt is enabled from not enabled, and the buffer is empty, then we should generate a TX IRQ immediately. Added: And the result: PIO_BASE for PIO 0: 16 RT-11SJ (S) V04.00H .D 56=5015 .TYPE V4USER.TXT Welcome to RT-11 Version 4. RT-11 V04 provides new hardware support and some major enhancements over Version 3B. Please use the HELP command; it describes the new options in many of the utilities. If you are using a terminal that requires fill characters, modify location 56 with a Deposit command before proceeding with system installation. LA36 DECwriter II and VT52 DECscope terminals do NOT require such modification. .D 56=0 Yay! Though it's not quite correct - we didn't see if the transmitter was empty, so we could do a double interrupt... FIXME! There seems to be a bit of trouble with the LTC: .TIME 9:46 .TIME 09:46:00 .TIME 09:46:00 More IRQ enabling issues? And we didn't do NXM properly, somehow: .SHO CONF RT-11SJ (S) V04.00H Booted from RK0:RT11SJ Resident Monitor base is 147252 (52906.) USR is set SWAP TT is set NOQUIET Indirect file abort level is ERROR Indirect file nesting depth is 3 LSI-11 Processor Parity Memory VT48 Graphics Display Hardware 60 Cycle System Clock KW11-P User Programmable Clock SJ timer support Thought I sysgenned out the KW11-P...
... And the story continues ...
11-oct-2026: But, before that, verifying that the board will actually boot RT-11 v5.07: .show conf RT-11FB V05.07 Booted from RK0:RT11FB USR is set SWAP EXIT is set SWAP KMON is set NOIND MODE is set NOSJ TT is set NOQUIET ERROR is set ERROR SL is set OFF EDIT is set KED FORTRAN is set FORTRA KMON nesting depth is 3 CLI is set DCL, CCL, UCL, NO UCF SBC 11/21 (T11) Processor 56KB of memory 60 Hertz System Clock FPU support Taadah! It actually booted - but not sure why it shows FPU support. Google reports this as a bug in the RT11 FPU detection code with respect to the T-11.
5.4 Then there the bugs that don't happen on the real thing
When debugging the M9312 code, noticed this gem: ; mov pc,sp ; save pc for display But, when the T11 takes an NXM HALT interrupt, it will write the PC/PSW to the stack. Well, the above instruction writes the current PC to the stack, so when we get this NXM, we will overwrite the ROM. Not a problem for a real M9312, but we don't have write protection on the ROM space since writes are completely under DMA control. That was fun to debug!
Also, since the m9312 doesn't actually set a stack pointer, if there's a NXM during boot, then we overwrite whatever we last used as variable during console interactions. Here's snippet from the log:
So, debugging further. Fired up an IO transaction capture on second core. Really need to improve the m9312 monitor, as it scribbles on IO registers if there's an NXM trap: WR: addr/data: 177416 000344 WR: addr/data: 177414 165364 RD: addr/data: 177414 165364
Lovely, right?
6.0) Next steps
Finish RL11 support
Have to make a race condition proof ISR/main handlers.
Add lights and switches register
Use a PIO instance to drive WS2811 based front panel display. May require a sysgen to activate, based on the RT-11v4 sysgen questions.
Add ethernet support
There is a M9312 Ethernet boot ROM, so that could serve as a starting point for test code.
See how hard GT-40 would be to emulate
Playing lunar lander would be cool.
