For many people is fun to experiment with old computers and explore possibilities that were impratical in the past days.
One of these is rom upgrade, an example is the Atari ST.
This computer has roms chips installed through sockets and is possibile to easily exchange with different versions of TOS.
In the process of these experiments I developed this little tool to program FLASH chips that in modern days replace the old write once ROM chips.
Main goal of the this project was to have an easy method to program flash chips using few components and without the need of a "companion" software to run on the pc.
I used the SST39SF040, a 4Mbit Flash rom, these chips operates with 5V and are compatible with old computers. chips were programmed and mounted on a "experiment" pcb
to test different OS for my Atari and have fun during this journey.
I wrote all my code manually because I wanted to test my current skills and got trapped into use of ANSI codes and terminal interfaces
