Hull optimisation finished
A project log for Flappy
Extremely robust boat drone to travel the Ocean from Portugal to Antactica and come back only with solar power.
clementdeymierclement.deymier • 11/12/2026 at 18:53•0 Comments
Hello, I received my 3D printer and printed the different hull prototypes at 1/4 scale in draft mode. A total of four iterations were needed to achieve this result, which handles waves well and moves forward properly; the earlier versions couldn't carry enough payload (estimated between 6 and 10 kg). The keel is currently a glued piece of iron, but in the final version, I will put lead inside a cylindrical keel bulb. I will soon print the boat at full scale (98 cm) to test the propulsion; I still need to add the shaft tunnel that will actuate the fin.
