Note : first analyses have been done with the valuable help of our friend Mistral AI
Chapter 1 : Choice of Mechanical Architecture and components
a/ Architecture
First thing is to determine which interaction will be between the bench and the DUT. It seems that two interesting possibilities should be available : first could be to insert a pneumatic T-tap between the monitor and the cuff, to inject directly the pneumatic stimulus inside the monitor. Second possibility is to create an artificial arm inside the cuff.
Here we have to notice that we may not have to represent a full realistic arm. The main goal is to respect maximum repeatability over time, in order to detect sensor drift over the years.
b/ Artificial arm material
Candidates examined: PET bottle (too rigid — 3× too fast deflation), latex balloon (replaced every 6 months — fails the 10-year requirement), platinum silicone bulb (gas permeability 10-25× butyl), Omron cuff bladder (flat shape), EPDM membrane accumulator (bulky, costly). Retained: 700c butyl bike inner tube — compliant (~0.1-0.3 mL/mmHg, comparable to an arm segment), the most stable and gas-tight elastomer, no creep when stored uninflated, original Schrader valve for sealing.
Form-holding textile sleeve: braided polyamide sleeve Ø 80-100 mm (Techflex F6 type): the geometry is set by the sleeve, not the elastomer. No foam by default (the most perishable part — the "zero consumable" architecture avoids it). Optional EPDM foam (not PE): if the ABP signal looks too "square" (rise/fall time ratio > 1.8, computed by the firmware), add one 3 mm closed-cell EPDM wrap between sleeve and cuff, and log the change. Markers: cuff position on the sleeve and number of Velcro notches, identical at every session.
c/ Drive choice to modelize dynamic blood pressure : syringe + eccentric cam (retained)
Rejected alternatives: rotary servo (backlash, hysteresis), linear servo, peristaltic pump (aging tube), proportional valve (cost, pilot air).
Chapter 2 : Pneumatics — sizing
a/ Static and dynamic pressures
b/ Calculations
Waveform: the butyl wall + sleeve naturally round the edges — no additional pneumatic RC filter. "Squareness" is continuously quantified by the firmware (rise/fall ratio; alert if > 1.8 → EPDM foam).
Chapter 3 : Limits and critical analysis
  1. A single "patient": one nominal point (100 mmHg, 60 bpm, one amplitude). We look for drift, not the complete error map. Possible extension: a second tube sealed at 120 mmHg ("hypertensive patient").
  2. Mechanical coupling not computable: everything is protocolized to make the transmission constant, but it is unknown in absolute value — the bench measures relative evolutions, never absolute accuracy.
  3. The standard drifts too: mitigations = accredited recalibration every 2 years (APB sensor) + cross-control chart with the aneroid gauge (two independent standards watching each other).
  4. Butyl still ages, slowly: stored at 0 mmHg it lasts well beyond 10 years; the leak test detects any micro-leak; visual inspection at every session (cracks on the folds).
  5. Check valves = the only soft active parts: doubly isolated during measurement (S1 + S4), their drift only affects inflation speed.
  6. Thermal sensitivity: ~0.4 mmHg/°C during a session — temperature logged, ±3 °C range vs the reference session.
  7. No clinical validation: the bench answers "has it drifted?", never "is it accurate?". Keep the annual comparison with a validated monitor.
  8. Device firmware: an algorithm update can change the response without hardware drift — log the device firmware version in every session sheet.
  9. Strengths: no elastic consumable in the drive chain (metal, bearings, air); mechanically defined stimulus (stop + cam), reproducible by construction; two cross-checked standards; the assembly under test operates strictly as original.
Litterature - existing projects :
Novel methods of testing and calibration of oscillometric blood pressure monitors (Branko G. Celler,Ahmadreza Argha,Phu Ngoc Le,Eliathamby Ambikairajah, Published: August 6, 2018)
Note sur la Systole Diastole :
A/A_max
 1,0 ┤        ╭──╮          ← max = MAP (100 mmHg)
 0,8 ┤    ╱          ╰──── ← diastole (~70-80 % A_max)
 0,5 ┤   ╱                 ↓
       │  ╱  ↑               pression du brassard
 0,0 ┤ ╱   ← systole (~50 % A_max)
        80  100  120  140  160 mmHg
