Looking at lower frequencies
A project log for Device for Seismic Noise Analysis
Could a digital device to analyze the statistics of the magnitude and 3-D origins of seismic noise predict some local earthquakes?
michael-doodyMichael Doody 05/13/2017 at 19:510 Comments
The charge amplifier on one of the seismometers has been changed to respond to 1.5 Hz and below. It was a simple resistor change, of the rightmost resistor on the handwritten schematic down below. The resistor was 1000 Ohms and now it is 10,000 Ohms.
Up until now the amplifier has been using a 15 Hz low pass filter. It's going to take a couple of days to collect enough data to get the device's sensors calibrated. The plan is to run the 1.5 Hz device and a 15 Hz device side by side until "something seismic" happens, then compare and contrast the results.
