Harmony Aftermath is an ESP32-C3 board that:
- talks to the original Harmony remote over its 2.4 GHz radio, just like the Logitech hub
- fills the room with IR from six LEDs pointing in different directions, so it reaches devices that aren't in front of it
- drives a plug-in Harmony IR mini blaster for gear hidden in a cabinet
- pairs with the remote from a web page, no Logitech account or Windows PC needed
- works as a Bluetooth keyboard and media remote for a PC
- adds Wake-on-LAN and Tasmota switches over HTTP
- fits inside the original Harmony Hub case
Harmony remotes are no longer made, but you can still buy them on eBay and from other sellers
Everything is set up in one JSON file uploaded over Wi-Fi. I don't write it myself: I just tell Claude what devices I have and what each button should do, and it writes and uploads the config. All I gave it was the README from GitHub
The parts list and schematic are here: https://github.com/sb-3000/harmony-aftermath/tree/main/hardware
What went wrong along the way
- The first IR attempt was weak. I started with two cheap YS-IRTM serial IR modules. They worked, but only at 1–3 m and only when aimed. TSAL6200 LEDs driven directly through transistors fixed it
- My AI coding partner said no. Claude wouldn't write code to put the nRF24L01 into promiscuous mode, which is how you sniff the remote's address for pairing
What's next
I'm thinking about ordering a proper PCB, maybe even fully assembled, and a custom case so you don't need an old hub to put it in. I'd also wanted to add support for the Apple TV remote and other remotes
Leave a comment or send me a PM if you'd like to get one!
