Why
Controllers like these usually die from one small fault: a worn contact, a dead wireless chip, a broken connector. The shell, sticks, triggers and motors are often still fine. ReChip Pad gives them a new brain instead of sending them to the landfill. It's part of a personal theme: giving old and broken hardware a second life with new chips and new code (see also my NavigatorOSM project, which turns retired iPads into car GPS units).
What it does
- Bluetooth LE HID gamepad (PC, Android, Steam) and USB-C wired mode, both from the ESP32-S3
- LiPo battery with on-board charging, in the original battery bay
- Rumble: drives the original two motors
- Guide button LEDs for status (pairing, battery, player)
- Wi-Fi mode (experimental): the pad talks to a small PC server that creates a virtual gamepad, and rumble goes back to the pad (server based on Joy2DroidX, GPL v3)
- Reuses the original sticks, triggers, bumpers and buttons
- Open Arduino firmware
- Planned: gyro. A 6-axis motion sensor (gyroscope + accelerometer) for gyro aiming. First on the DIY board with a breakout module, then on the 4-layer board. Standard Bluetooth gamepads have no motion data, so the gyro will reach the PC over USB (by presenting a controller Steam already reads motion from) or over Wi-Fi through the PC server
Two versions
- Full board (4 layers): everything on one PCB, designed for JLCPCB fabrication and assembly. Fully routed, DRC clean and reviewed; I'll order it once the DIY board has been tested.
- DIY "wired" board (2 layers): a simple, cheap board with the controller's footprints, wired by hand to an ESP32-S3 dev board through a 2×15 header. Hand-solderable through-hole parts only. This is the first prototype: 5 boards made and in the mail.
There's also an experimental no-PCB variant: two 3D-printed halves with copper tape traces, for people without access to a fab.
Status (honest)
- ✅ Board outline and mounting fit-checked with a 3D print
- ✅ Donor parts measured (button contacts, battery polarity, board thickness) and checked against the design
- ✅ DIY 2-layer board routed, DRC clean, fabricated (5 boards, in the mail)
- ⬜ DIY board assembled and tested
- ✅ Firmware compiles (BLE + USB HID), pin map checked against both PCBs by a script
- ✅ Firmware running in a Wokwi simulation, including Wi-Fi mode and rumble from the PC server
- ✅ 4-layer board fully routed, DRC clean, design review done and fixes applied
- ⬜ Firmware tested on real hardware
- ⬜ Motion sensor (gyro) tested on the DIY board, then added to the 4-layer board
- ⬜ 4-layer board ordered (after the DIY tests)
- ⬜ Build guide and full file release
License
Hardware: CERN-OHL-S v2. Firmware: MIT. PC server: GPL v3 (it's a modified Joy2DroidX). All files will be published as they stabilize.
Note
This is a hobby project done in my spare time (I'm a CTO by day). Updates come when they come, but they'll be honest: failures included.
"Xbox" and "Xbox 360" are trademarks of Microsoft. This project is not affiliated with or endorsed by Microsoft and contains no Microsoft code or designs; "360-style" refers to the shell form factor only.
nik2208
