RFID animal microchip scanner hack
Tuning the RFID-scanner
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Hacking (or destroying???) the RFID animal microchip scanner.
Since the cheap (costs about €20) RFID scanner only has a range of around 15 cm, I want to take it apart and fit it with a larger antenna so that I can read animal ear tags from a distance of about 30 cm, or hopefully even more. Ideally, it would then be mounted at a passageway so that it can detect the sheep.
Since I also want to control the scanner using an Arduino, I had to solder two wires to the top button so that I can trigger it via a relay from the Arduino. The scanner then transmits the scanned ear tags via the USB port.
