I programmed with AI tools a useful data viewer for oscilloscope and other measurement files. Currently .bin and other Keysight oscilloscope formats supported. Also custom .mat files. You can also load data from a Measurement receiver or s4p. files from vector analyzer. I use it at work and at home and should be easy to use with most of the functions just drag and drop. I implemented some useful functions like statistics and filters. Also a file converter is included to convert from mf4 or yokogawa wfv to a .mat file. If you have some suggestions of functions that are useful or file formats I can also implement them when I have time. Maybe this is useful for somebody else. Its programmed in python so it can be used on linux and windows. For windows I created a .exe so no install needed. Just execute. For linux there is a build script or just run it with your python environment. Detailled descriptions are on my github. https://github.com/mrblackchris/opencaliper.
