The Idea Behind NaviGo V2.0
Navigating complex 3D models and CAD assemblies with a standard mouse and keyboard shortcuts slows down your workflow, while commercial 6-DOF controllers are expensive and most DIY alternatives rely on delicate multi-gimbal mechanics or complex Hall-effect sensor arrays.
NaviGo V2.0 takes a minimal electromechanical approach: instead of a complex gimbal assembly, the knob rides on a 40mm 3D-printed compliant flex spring paired with an ADXL335 analog accelerometer to read smooth 3D tilt, combined with three TTP223 capacitive touch sensors for instant mode switching (Orbit / Pan) and Zoom In/Out. An addressable WS2812B LED ring under a 3D-printed diffuser provides real-time visual feedback for the active mode.
Mechanical Architecture (9 3D-Printed Parts)
The entire enclosure is designed for straightforward FDM 3D printing
  • Base Assembly: Bottom base, upper housing, internal LED ring holder, and light diffuser cover.
  • Core & Sensing: Fixed central column holding the ADXL335 sensor bracket and the 40 mm compliant spring that provides smooth tilt and reliable return-to-center.
  • Control Knob: Ergonomic outer knob shell topped with a 2 mm capacitive touch cap.
Electronics & Pinout Overview
The circuit runs cleanly off a single 3.3V rail using a Waveshare RP2040-Zero, a small 2×6 stripboard power rail, and 15 cm flexible silicone wires for unrestricted knob movement:
  • Microcontroller: Waveshare RP2040-Zero
  • Motion Sensor: ADXL335 3-axis analog accelerometer (XOUT → GPIO 26, YOUT → GPIO 27 ADC; firmware also supports I2C sensors on the same pins)
  • Touch Controls: 3× TTP223 capacitive touch modules (GPIO 4 under the top cap for Orbit/Pan toggle, GPIO 2 & GPIO 3 on the side for Zoom)
  • Visual Feedback: WS2812B addressable LED ring (GPIO 0 data, powered at 3.3V) — completely optional for aesthetics
Native Software & CAD Integration (Windows & Linux)
Instead of relying on clunky keyboard-shortcut emulation, NaviGo V2.0 talks directly to native add-ins across 8 major 3D and CAD suites:
  • Blender
  • Autodesk Fusion 360
  • FreeCAD
  • Autodesk Inventor
  • Autodesk 3ds Max
  • Autodesk AutoCAD
  • Autodesk Maya
  • Unity
Setup is handled by a cross-platform Python/Tkinter Universal Installer for both Windows and Linux, covering automatic add-in installation and firmware flashing.
Get the Files, Software & Updates
