Start by solder deepsleep jumper. (See build instruction)
Solder the DHT11 to 3.3V, GND and pin 2. You don't need a pullup for pin 2 as it already is placed there for boot-modes.
Go to thingspeak.com and find your ID and API-key. Also make sure that field 1 and 2 is active.
Change ssid, pass, id and apikey for your settings:
#include <ESP8266WiFi.h>
#include <PubSubClient.h> // MQTT
#include <SimpleDHT.h> // DHT 11 sensor
#define sleepTimeS 600 //10 min Time between updates
// --- PINOUT ---
const int temp_sensor_pin = 2;
const char* ssid = "ssid";
const char* password = "pass";
const char* mqtt_server = "mqtt.thingspeak.com";
String temperature_topic = "channels/id/publish/fields/field1/apikey";
String humidity_topic = "channels/id/publish/fields/field2/apikey";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
byte temperature;
byte humidity;
SimpleDHT11 temp_sensor_obj;
void setup() {
//Wifi
WiFi.begin(ssid, password);
int wifiTryConnectCounter = 0;
while (WiFi.status() != WL_CONNECTED)
delay(500);
wifiTryConnectCounter++;
if (wifiTryConnectCounter >= 10) //Try to connect 10 times or go to sleep
ESP.deepSleep(sleepTimeS * 1000000);
//MQTT
client.setServer(mqtt_server, 1883);
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str())) {
//Success
} else {
//Sensor
int err = SimpleDHTErrSuccess;
if ((err = temp_sensor_obj.read(temp_sensor_pin, &temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
//Send
snprintf (msg, 75, "%ld", (int)temperature);
client.publish(temperature_topic.c_str(), msg);
snprintf (msg, 75, "%ld", (int)humidity);
client.publish(humidity_topic.c_str(), msg);
//Sleep and repeat
client.loop(); // MQTT work
void loop() {
// Will not run
Upload to the board and enjoy the temperature graph in thingspeak :)
