Just for completeness' sake, I coded up an implementation of XEX for Orthrus just to do a speed comparison. It's a third slower - around 150 KB/sec instead of 225 KB/sec. I'm fairly confident that most of this stems from the fact that the encryption cannot be precomputed in the background and must be done interactively as the block is read and written from the card. It's not as bad as I had feared, but it's certainly an impact on what is already quite a slow mass storage device.
Still, I think the weakness of straight counter mode make the changeover to a very widely used encryption mode for the given purpose seem like a good move. With this change, we can truly say with a straight face that we're doing whole-disk encryption using universally accepted standards.
Incidentally, if you google it, you'll find that most implementations of WDE talk about using XTS rather than XEX. However, the two are equivalent if the disk sector size is an even multiple of the cipher block size, which is the case for us. Some implementations use two separate keys - one to encrypt the nonce to form the tweak and one to encrypt or decrypt the data. However, the value of doing that seems (in the literature) to be disputed, so we just use the same key for both. If we had to pick two different keys, we could do so by cutting the volume ID in half and performing the key derivation twice - once on each half.
