In searching around for information about the state of the art in WDE, I came across this particularly interesting article.
One problem with whole-disk encryption is that you're generally not allowed to alter the block size. At this point, it's almost completely universal that we use disks (or pseudo-disks) that are simple one-dimensional arrays of 512 byte blocks.
One desirable quality of encryption is that you'd like to know if someone tried to tamper with the ciphertext. In general, this means either using authenticated modes or adding a MAC to the ciphertext. Unfortunately, this means that the ciphertext (or ciphertext plus MAC) is longer than the plaintext. For WDE, this is untenable.
Since we can't add any bits to the block to authenticate the content, the best we can do is try to use encryption to perturb errors so that an adversary can't, for example, be allowed to flip arbitrary bits in the ciphertext to flip the same bits in the plaintext. Such an adversary would be able to modify files in place, which is almost as good as being able to read them.
XEX (or XTS) will cause a 16 byte corruption in decrypting a block that has a single bit flipped. That blunts an attacker's ability to modify files. It would, however, be better if the mode could cause an entire block to be corrupted beyond recognition if a single bit of the ciphertext is altered. This property is called diffusion. Diffusion and confusion are two basic properties of a cipher. Confusion means that each bit of the ciphertext relies on more than one bit of the key, and that different bits of the key combine in an unpredictable pattern to alter bits of the ciphertext. Diffusion means more or less the same thing with regard to the plaintext during encryption and ciphertext during decryption. Altering one input bit will cause radical changes to the entire output. Both confusion and diffusion are necessary to prevent statistical analysis of a cipher. This was all worked out by Shannon in 1945.
Ideally, we'd use a 4096 bit block size cipher for WDE, but that isn't practical. XEX provides confusion by perturbing the plaintext and ciphertext on both sides of the encryption operation, but because it handles each 16 byte AES block individually, it supplies no diffusion.
So far as I can find, since the BitLocker post was written, there haven't really been significant advances on the diffusion front for WDE. So far as I am aware, most solutions still use plain XTS (or XEX), meaning that a single bit flip will cause a 16 byte aligned block diffusion error and no other changes beyond. It certainly blunts bit-flipping attacks, but doesn't really eliminate every possibility of efficacy.
What does this mean for Orthrus? Not much. Orthrus differs from most WDE systems in that Orthrus isn't really intended to be a primary volume (not something on which you'd install an operating system to boot) so much as an offline storage system. It's intended to take away the job of key management for a particular, limited use case. So we're going to stick with XEX.
