I changed the original vision slightly by removing the option of doing an internet speed test. I decided I didn't want to deal with having to redesign and reprogram if the internet speed test API changed or went offline.
For the frosted decal I used the website BannerBuzz with the image I designed.
I designed the enclosure in Autodesk Fusion 360 to be 3D printed.
