I have a Sanguinololu around from my previous project:
For the motor controllers I will use the SilentStepStick once again. Most probably I will stretch the driver to it's limits, so I've decided to go with a slave setup where Two motors power the fast axis.
For the fast axis I will use two THK rails from Ebay, each with their own stepper to distribute load across two drivers.
