With the ALU verified and the RAM connected, today the breadboard determined that the first 8-bit Fibonacci number is 144.
0000 0000 ld $00 ; outer loop 0001 c200 st [$00] ; a=0 0002 0001 ld $01 ; b=1 0003 fc0a bra $0a 0004 0200 nop ; (pipelining) 0005 0100 ld [$00] ; inner loop 0006 c202 st [$02] ; tmp=a 0007 0101 ld [$01] 0008 c200 st [$00] ; a=b 0009 8102 adda [$02] 000a c201 st [$01] ; b+=tmp 000b 1a00 ld ac,out ; emit next Fibonacci number 000c f405 bge $05 ; repeat if bit7 is still 0 000d 0200 nop ; (pipelining) 000e fc00 bra $00 ; start over again 000f 0200 nop ; (pipelining)
The inner loop runs 12 times (1, 1, 2, 3, 5, .... 89, 144). The entire thing takes 110 cycles. Both are exactly as expected. It can be done faster but I didn't optimise the assembly to maintain my sanity.
I also hooked up a cute little MCP100-475 to the program counter reset line. This gives a controlled reset during power up. The circuit is now 90% wired. Only the high memory address control and some diodes are missing for full functionality.
Nice work :)
Thank you! Last two weeks were an uphill struggle, but it should be a much easier ride from here on.
