It seems I have reached the base camp. The el-cheapo 7-inch LCD monitor on the right is connected to the output port of my breadboard TTL computer. The computer is now running at 6.3MHz and runs a software loop that generates a VGA test signal. The colors look a bit off, and still not all wiring is done and tidied up, but the mountain top is definitely in sight.
As far as I can check with the oscilloscope, the signals are behaving nicely according to the VGA industry standard 640x480 at 60Hz. Yellow is the vertical sync and light blue is the horizontal sync.
The disassembly of the code:
0000 0009 ld $09 ; setup for 10 lines vertical front porch 0001 a001 suba $01 ; next line in vertical blank 0002 c200 st [$00] 0003 0200 nop 0004 0008 ld $08 ; entry point for starting a new frame, inside the first hsync 0005 ec05 bne $05 0006 a001 suba $01 0007 0200 nop 0008 18c0 ld $c0,out ; end of first hsync in frame 0009 0055 ld $55 000a ec0a bne $0a 000b a001 suba $01 000c 0100 ld [$00] 000d ec01 bne $01 000e 1880 ld $80,out ; new hsync start 000f 000a ld $0a 0010 ec10 bne $10 0011 a001 suba $01 0012 18c0 ld $c0,out ; hsync end 0013 0054 ld $54 0014 ec14 bne $14 0015 a001 suba $01 0016 1840 ld $40,out ; vsync start 0017 0200 nop 0018 0200 nop 0019 0200 nop 001a 1800 ld $00,out ; hsync during vsync 001b 000a ld $0a 001c ec1c bne $1c 001d a001 suba $01 001e 1840 ld $40,out ; hsync end 001f 0056 ld $56 0020 ec20 bne $20 0021 a001 suba $01 0022 1800 ld $00,out ; hsync during vsync 0023 000a ld $0a 0024 ec24 bne $24 0025 a001 suba $01 0026 1840 ld $40,out ; back porch 0027 0054 ld $54 0028 ec28 bne $28 0029 a001 suba $01 002a 18c0 ld $c0,out ; 33 lines black 002b 0200 nop 002c 0200 nop 002d 0020 ld $20 002e 1880 ld $80,out 002f a001 suba $01 0030 c200 st [$00] 0031 0009 ld $09 0032 ec32 bne $32 0033 a001 suba $01 0034 18c0 ld $c0,out 0035 0055 ld $55 0036 ec36 bne $36 0037 a001 suba $01 0038 0100 ld [$00] 0039 ec2f bne $2f 003a 1880 ld $80,out 003b 000a ld $0a 003c ec3c bne $3c 003d a001 suba $01 003e 18c0 ld $c0,out 003f 0055 ld $55 0040 ec40 bne $40 0041 a001 suba $01 0042 0200 nop 0043 00e0 ld $e0 0044 1880 ld $80,out 0045 a001 suba $01 0046 c200 st [$00] 0047 0009 ld $09 0048 ec48 bne $48 0049 a001 suba $01 004a 18c0 ld $c0,out 004b 0004 ld $04 004c ec4c bne $4c 004d a001 suba $01 004e 18d5 ld $d5,out ; first colors 004f 0003 ld $03 ; 9 clock delay 0050 ec50 bne $50 0051 a001 suba $01 0052 18d7 ld $d7,out ; second color bar 0053 0003 ld $03 0054 ec54 bne $54 0055 a001 suba $01 0056 18dd ld $dd,out ; third color bar [...snip...] 008a 18ea ld $ea,out ; last color bar 008b 0003 ld $03 008c ec8c bne $8c 008d a001 suba $01 008e 18c0 ld $c0,out ; back to black (front porch) 008f 0200 nop 0090 0100 ld [$00] 0091 ec45 bne $45 ; repeat for 480-256 = 224 lines 0092 1880 ld $80,out ; hsync start 0093 a001 suba $01 0094 c200 st [$00] 0095 0009 ld $09 0096 ec96 bne $96 0097 a001 suba $01 0098 18c0 ld $c0,out ; hsync end 0099 0004 ld $04 009a ec9a bne $9a 009b a001 suba $01 009c 18ea ld $ea,out ; second half of screen (256 lines) 009d 0003 ld $03 009e ec9e bne $9e 009f a001 suba $01 [...snip...] 00e1 0008 ld $08 00e2 fc04 bra $04 ; to new frame 00e3 c200 st [$00]
