There are several methods brewing for hooking up a keyboard. The one most in line with the system is WattSekunde's four chip design for a matrix keyboard interface. But such keyboards might be hard to find, while PS/2 keyboards are still easy to get. But their protocol is convoluted and it is unclear how to handle that with a few simple logic chips. So... we cheat!
PS/2 is simply too modern, and we need a time machine to translate its fast and complex signals to the simple signals that the Gigatron will understand. The ATtiny85 will be our Babel fish.
To get some idea: the ATtiny85 must be configured to run at 8 MHz to do its magic. 1 MHz won't be good enough to catch and transfer simple key strokes. Here is the system in action:
Very neat and compact! But if you're going to cheat by using a micro, then you might as well bring it up to the modern keyboard standard USB. I believe you can do it with a single micro as well, but maybe not as elegant as the 8-pin ATtiny. This is probably why so many early computers had their keyboards built-in (maybe in the Gigatron 2?)
That was the previous phase, but it used an Arduino Uno and that has two micro controllers, one for the USB. Next step is to remove the PS/2 guts from the keyboard and drive the matrix from TTL :-)
