A bunch of TTL chips playing the "anthem of 8-bit computing". Four channels: 2x pulse, 1x triangle, 1x noise
The player is an enhanced version of the Contrib/at67/midi player in the gigatron-rom repository. The noise is created from waveform 0 ("metallic") that receives a randomised XOR modulation 60 times per second.
Only 7400 logic. No microprocessor, no video chip, no sound chip.
![](https://cdn.hackaday.io/images/8800001565690691305.png)
The Arduino is used to load the music and player into RAM. You see that happen in the first few seconds of the video.
