First some perspective:
Yes, the ALU will be made out of multiplexers! (74LS153)
The 74LS155 that is to become a 3-to-8 opcode decoder, the bottom half of the diode ROM matrix and the inverter/buffer row (74LS04). You can see XOR, OR, AND and LOAD programmed here.
