This is the glitch I was still contemplating yesterday:
It isn't a EEPROM timing issue after all. Low signals into the instruction decoder just weren't always low enough. The culprit turned out to be the IR register's ground pin:
Signals look much better with that sorted out:
Next is the verification of the ALU.
solderless breadboards are lousy :-(
They are good for prototyping. I doubt I can get it working by soldering everything from the start. I make many mistakes.
