Indeed, the plans to consolidate the breadboard into something more robust begin to materialise.
(And yes, U29's pin 10 isn't soldered due to a little bug.)
A project log for Gigatron TTL microcomputer
Just because! A home computer without microprocessor
Thanks Dylan! I'm now waiting for some parts to arrive (jacks, resistor arrays) so I can continue debugging. It is my first PCB ever.. The board should be compatible with the breadboard computer, except that I now work with the larger capacity 27C1024 EPROM. They seem perfect for the design. Instead of the two 32K 8-bit EEPROMs of before, I can use a single 27C1024 and fill the entire program space AND get 16-bits words. As if this chip was made for this design.
The board looks great Marcel!
