- Arduino Leonardo compatible
- Program board using the Arduino IDE
- Atmel ATmega32U4
- USB-Mini connector
- Standard connection as USB peripheral
- ATMega32U4 has a built in USB interfaces so it does not require an FTDI part
- Three flexible power options - Jumper controlled
- Power from the USB port
- The USB input is polyfuse protected
- Power from External VIN pins (> 6.5V required)
land-boards.com
