Designing the new and improved revision 1 of the USB 3 nanohub now. I'm upgrading from TUSB8020 to USB5742, which means:
- power consumption is lowered by 10-20%
- support for the USB 3.1 protocol now (still 5GBps though)
- board size reduced from 20x20 to 20x15mm
The USB 3.0 hub has been out of stock for a while, and it will stay out of stock until these boards are in - probably around 15 Sept. But it's going to be worth the wait!
It's so small!
