A requirement for my PotBelly PWM units (see moxbods group on facebook)to be able to run on 28-30v supply necessitated a LDO implementation, and I decided to at the same time add a digipot to the board.
The board can also be used as an LDO only if need be, as it has through holes for the standard potentiometer.
I had the boards produced by pcbway.com and they are excellent quality and finish.
