Ok so more progress for today. I implemented many key (unique but a little obscure) features of the TMS9900. Still testing under simulation. I decided to postpone actual hardware synthesis until I have all the instructions somehow implemented. After these additions there are not many instructions missing anymore.
- Now the core can process the most complex TMS9900 instructions, BLWP and RTWP.
- I also added all shift instructions SLA, SRA, SRC and SRL. These are fairly standard shift instructions as can be found in most processors.
- The TMS9900 architecture has a unique serial I/O facility called the CRU interface. This interface supports single bit and multiple bit transfers, using 5 instructions overall. Now the core implements the single bit variety, with SBO, SBZ and TB instructions. The multiple bit instructions are not yet there (LDCR and STCR).
I tested all of the above in simulation. Not comprehensively, especially regarding flags. But BLWP and RTWP work - I actually changed reset processing so that reset is done by forcing a BLWP from address 0. BLWP does a ton of stuff:
- It has a source operand, which supports the normal slew of addressing mode.
- Once the effective address of source operand is calculated, two 16-bit words are read from there: the new workspace pointer and the new PC.
- As the CPU enters the new workspace, it saves the entire context of the CPU to the new workspace by writing old WP to R13, old PC to R14 and old flags (ST) to R15.
- Finally the new workspace is entered and new execution pointer is established by loading W and PC.
When doing the above, care must be taken since to capture the old values of the registers W, PC and ST before overwriting them with the new ones.
RTWP is an easy instruction - it has no operands. But it also does plenty: it reverses BLWP by loading W, PC and ST from R13, R14 and R15.
The shift instructions SLA, SRA, SRC and SRL are also flexible in that the operand to be shifted can be chosen flexible with the full slew of addressing modes. The shift count can be given as an immediate argument. If set to zero, shift counter is actually read from workspace register zero. In that case the four LSBs of R0 are used as a shift count. And there is a catch there too - if those four LSBs of R0 are zero shift count is actually 16. I think for the shift instructions the carry and zero flags at least are set properly but not sure yet of the other flags...
The single bit CRU instructions are also unique in that they use a special addressing mode that none of the other instructions use: the 8 LSBs of the instruction word become a sign extended offset to R12 for I/O bit addressing. Not only that - the 3 MSBs of I/O address are always zero and the offset is left shifted by one... The instructions are:
- SBO <offset> - write a one bit to R12+offset. This is done by driving CRUOUT data line to one and issuing a clock pulse on CRUCLK. The CRUOUT is only valid when CRUCLK is high. Since the core is intended to run at 100MHz a single cycle CLKOUT may be too fast, so I added a delay counter which keeps CRUCLK high for 4 cycles.
- SBZ <offset> - the same as above but writes a zero bit.
- TB <offset> - calculates the I/O bit address as above, and then samples the CRUIN signal. For this one I also allowed four cycles of stable address output before sampling CRUIN.
