An update after a long last!
The next step for the design is to make the FPGA system stand-alone, i.e. able to boot and operate without a host PC. A USB connection will still be needed, but only to provide power. Today I implemented a new feature, where after reset the FPGA logic will load 256K of data from the SPI flash ROM to the SRAM of the system. That allows the system get the TI-99/4A system ROMs and GROMs to the static RAM in appropriate places. After the download one of the DIP switches controls the CPU's automatic boot - if switch zero is set the CPU in the FPGA will automatically boot and start executing the code that was transferred to SRAM.
The 256K of data is divided into three regions:
- First 128K is written to SRAM from address zero upwards. The logic of the FPGA maps this area to the cartridge ROM slot of the TI-99/4A. This is a paged are of 8K pages. By default my scripts but the extended Basic ROM code (16K there).
- Next 64K are written to SRAM from address 0x80000 onwards (at address 512K). This is the area where GROM data is stored in my design. By default I have there first 24K of system GROM followed by 32K of Extended Basic GROM code.
- The last 64K are written to SRAM at address 0xB0000. This is my ROM area. It is largely unused, but the first 8K (at address 0xB0000) are the disk support DSR space and another block of 8K (at address 0xBA000) is mapped to address zero of the TMS9900 core's address space, thus containing the normal console ROM code.
The Pepino board has 1M of static RAM overall. I had forgotten that the board has actually 16 megabytes of SPI flash storage so there is plenty of potential here.
The design of the SPI flash interface is from Magnus Karlsson, the designer of the Pepino FPGA board. I used the code from his Mac Plus example, and modified the code for my purposes. His code is written verily while my code is in VHDL, so I wrote the standard VHDL component header to enable me to interface the Verilog code from VHDL.
Erik Piehl
