I got a LiFePo4wered Pi power source from Patrick some time ago.
This is a great little power unit. A 18650 joins up with the GPIO pins and hangs off the side of the Pi. For my application, I will need the LiFePo above a Pi Zero. A few minor alterations should put things where I need them.
