Got to try the new heated bed out today and got some stats.
It took about 5 minutes to heat to 90C, starting from 25C.
Surface temp was pretty even. It was about 3 degrees cooler near the edges, and varied by about 1 degree otherwise across the surface. Where I had attached the feed wires, it was about 5 degrees cooler.
Good enough.
MasterOfNull
