// LIBRARIES
#include <VirtualWire.h> //Library for the Radios
#include "DHT.h" //Library for the DHT11 Sensor
// DEFINES
#define DHTPIN 12 //DHT Output on D4
#define DHTTYPE DHT11 //DHT Type (11,21,22)
// VARIABLES
const int led_pin = 13; //LED on D13
const int transmit_pin = 2; //Radio input on D12
// DATA STRUCTURES
// If you are not familiar with Data Structures visit this link http://www.cplusplus.com/doc/tutorial/structures/
struct package //Struct Type Name
int temperature ; //Struct Member
int humidity ; //Struct Member
int rain;
int soil;
typedef struct package Package; //Define name of
Package data; //Object name
// LIBRARY CALLS
DHT dht(DHTPIN, DHTTYPE); //Create instance of DHT called dht
// SETUP
void setup()
vw_set_tx_pin(transmit_pin); //initialize radio on D12
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(500); // Bits per sec
pinMode(led_pin, OUTPUT); //set LED for output
pinMode(A0, INPUT);
pinMode(A1, INPUT);
// MAIN LOOP
void loop()
digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
readSensor(); //Call readSensor function
vw_send((uint8_t *)&data, sizeof(data)); //send data (struct array)
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(led_pin, LOW); //LED off
delay(2000); //wait 2 seconds
// FUNCTIONS
void readSensor() //readSensor function
dht.begin(); //initialize dht
delay(1000); //wait 1 second
data.humidity = dht.readHumidity(); //get humidity & store in Struct variable data.humidity
data.temperature = dht.readTemperature(); //get temperature & store in Struct variable data.temperature
data.soil = analogRead(A0);
data.rain = analogRead(A1);
