// LIBRARIES
#include <VirtualWire.h>
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
// VARIABLES
const int led=13;
const int receive_pin = 2;
char temperatureChar[10];
char humidityChar[10];
// DATA STRUCTURE
struct package //Struct Type Name
int temperature = 0; //Struct Member
int humidity = 0; //Struct Member
int soil =0;
int SV = 40;
int WT = 22;
int smVal = 0;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); //LCD Structure
typedef struct package Package; //Define name of
Package data; //Object name
// Signs
byte droplet[8] = //icon for droplet
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B10001,
B01110,
byte thermometer[8] = //icon for thermometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
byte WTermo[8] = {
B11111,
B10001,
B10001,
B11111,
B11111,
B00100,
B00100,
B00100
// SETUP
void setup()
Serial.begin(9600); //start serial comms for output
pinMode(led,OUTPUT); //LED set for output
pinMode(SV, OUTPUT);
pinMode(WT,INPUT);
vw_set_rx_pin(receive_pin); //initialize receiver on pin D12
vw_setup(500); // Bits per sec
vw_rx_start(); // Start the receiver PLL running
lcd.begin(16,2);
lcd.backlight(); // finish with backlight on
lcd.createChar(1, thermometer);
lcd.createChar(2, droplet);
lcd.createChar(3, WTermo);
lcd.clear(); // clear the screen
// MAIN LOOP
void loop()
uint8_t buf[sizeof(data)]; //unsigned int 8 bit called buf with size specified in Struct member data
uint8_t buflen = sizeof(data); //unsigned int 8 bit called buflen with size specified in Struct member data
if (vw_have_message()) //Check for activity
smVal = map(data.soil, 0, 1023, 0, 255);
int WTemp = digitalRead(WT);
int WWTemp = map(WTemp, 0, 1023, 0, 255);
digitalWrite(led,HIGH); //flash LED
vw_get_message(buf, &buflen); //get the data, store in variable buf with length of bufflen
memcpy(&data,&buf,buflen); //memcpy ( void * destination, const void * source, size_t num );
Serial.print((int)(data.temperature*1.8)+32);
Serial.print("|");
Serial.print((int)data.humidity);
Serial.print("|");
Serial.println((int)smVal);
Serial.print("|");
Serial.println((int)WTemp);
Serial.print("|");
if (smVal <= 89)
Serial.print("Done Watering!");
Serial.print("|");
else if (smVal > 89)
Serial.print("Watering Now..");
Serial.print("|");
lcd.clear();
lcd.print("TEMP");
lcd.setCursor(6, 0);
lcd.write(1);
lcd.setCursor(8, 0);
lcd.print((data.temperature*1.8)+32);
lcd.write(0b11011111);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("HUMI");
lcd.setCursor(6, 1);
lcd.write(2);
lcd.setCursor(8, 1);
lcd.print(data.humidity);
lcd.print("%");
delay(2000);
if (smVal <= 89)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("WATER TEMP");
lcd.setCursor(11, 0);
lcd.write(3);
lcd.setCursor(13, 0);
lcd.print(WTemp);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Watering now :)");
if ((WTem*1.8)+32) > 74)
digitalWrite(SV, HIGH); //Valve Close
delay(10000);
else if ((WTem*1.8)+32) < 61)
delay(10000);
else {
digitalWrite(SV, LOW); //Valve Open delay(3000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Water Temp");
lcd.setCursor(12, 0);
lcd.write(3);
lcd.setCursor(14, 0);
lcd.print(WTemp);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Done Watering");
digitalWrite(SV, HIGH); //Valve close
delay(2000);
