• Version 5 and variants
    mclien • 11/10/2024 at 18:04 • 0 comments
    OK, a lot has been done since the last log.
    Drawbacks from the first real live version:
    Fitting of the pieces:
    Making a tight fit with wood is not a great idea, if you use it in the semi-outdoors, even when it is used inside a tent (which we do). There will be still too much difference in temperature and humidity, that may have one of the 2 cases: much humidity will makes the use if a hammer necessary to (dis-)assemble the parts. Dry environment will make the stools disassemble while carrying around. Imagine you just want to move the stool a bit, while you sit on it, grab it by the deck and just "hopp" a bit to the side together with your butt. The the deck disassemble and you caught your hand between the deck and the lower construction (did that once, no fun).
    Design:
    While "just rectangle" is a nice working concept, I imagined something more pleasing for the eye.
     Comfort:stools are the right choice at the workbench, but form time to time, when we sit down for meals, we quickly missed a backrest.
    So to deal with those issues some changes were made:
    -the diagonal beams of the table were reduced to half the thickness (which is the thickness in the weak-spot anyways: The cross-section). The beams have now a slight offset and no cutout at the crossing, but a peg to interlock.
    -the thinner beams give room in the box for backrests, which can be inserted in the stools.
    -the stools are constructed with some tolerance for easy (dis-)assembling. the deck is hold in place with concealed magnets.
    -outlines changed into a spline instead of a straight line.
    There is also a variants with chairs instead of stools in development, but since we don't have an urgent need for tose, it is not really finished yet.
    So pictures:
    Sorry, only found a pic from the whole set with the first chair prototypes (which won't work, bc they topple over to easy)
    The stool (parts, stool, stool with backrest):
    And the first (and only) new chair design (a working one):
    And here a pic from how the magnetic interlock works (again the non working chair prototype, but the principal is the same):
    There are still a few adjustments to make, but that is mostly about some minor things. Tolerances a bit tighter, a bit longer rest for the table, a stencil to get the the washers for the magnets in the right place..
    There is one trick, I have no pics from. As the pattern to fit everything into the box is quit "specific" and not to easy to remember, the manual for that is engraved in the underside of the middle table piece (which is the lid of the box and therefore the last part to place).
  • aaaand the real thing!
    mclien • 10/15/2017 at 17:16 • 0 comments
    OK, has been a while, sorry for that.
    here is one pic of the making using our CNC mill in the local Fablab (www.hafven.de):
    That is one of tables top parts.
    We made 2 sets in one go, to have the needed places for our goldsmithing workshops. And here is an impression of the finished set(s):
    Set one (left) is in the packted-for-transport state (the grey tension belt is the only additional part), set 2 (right) is the ready-to-use state.
    It manly worked out fine. Only I underestimated the amount of  working the wood did, when oiled and exposed to moisture. So we had to do quite a bit of grinding and milling afterwards to make the parts fit without the need to use a hammer all the time.
  • Modell v3 and packaging details
    mclien • 04/08/2017 at 15:21 • 0 comments
    I refined everything a bit. And here is some detail about packaging:
    that's how the stool parts interlink with the Tabletops to form the basic box:
    All interlinking parts in place:
    Next step, one stoolpart and 3 stool tops:
    Some more layers of stool parts later:
    While this all stays in place easily, the beam parts are a bit trickier. So I thought about placing some wooden plugs in the right places of the beams (represented by nails in the model. Easy to push in with pliers, since it's cottonwood):
    first parts interlinked in the box:
    (all parts of the same shape have the plugs in the same place,so you cant put them in wrong places)
    All beams in place (point symmetrical, so the center of gravity is the middle of the box):
    Last parts and the missing stool part (which is hold in place by the top of the box). The small beams fixed to the tabletop hods in in place):
    comparison v2 and v3 of the box. Improved things
    • hight reduced
    • fixed the handle holes
    • box topping much wider,so you can stack the boxes
    • all side walls start ad ground level, which should make assembly easier
    I also calculated the volume of all parts together: 100 cubic dm (so made from water it would be 100 kg).
    I intend to make it from spruce, which should be ~50kg (oak would be about 85kg..)
    Next up: Building the real deal. Difficult part might be to find the right wood, because for some reason wood comes in strange measurements in germany (19, 22, 24, 27 mm in thickness). But for the scaled down model, I could get hands on plywood with the exact scaled down thickness, so I designed with round values (20, 40, 60, 80 mm)
  • 1:5 Model v2
    mclien • 04/04/2017 at 20:14 • 0 comments
    After some more CAD work, here is the next version.
    I changed the Assembly of the higher stools (which build the small sides of the box). It is now 4 parts to get a box with less hight :
    As you can see the left one is slightly higher, has handle holes and 2 overlapping pieces.
    All parts disassembled / partly assembled:
    And completely assembled / and nicely fit in the new much less high box:
    As you can see I also changed the top of the table to 3 pieces, from which I plan to use the middle one as cover plate of the box.
    I'll tweak the design a bit more to have the cover plate, the site walls of the box and the long beams at the same hight when boxed.
  • CAD work and first 1:5 model
    mclien • 04/02/2017 at 18:18 • 0 comments
    So the first ideas a scribbled on paper and started on the CAD with that. Main course of action was to thing about the general measurements and then start the design in the assembled stage of the furniture. The next step is scaling the whole thing down by 0.2 (or 1:5) an use some plywood and a lasercutter to get a nice functional model. All parts that interlink an need some milling for that like the crossing beams (common halving/ Überblattung) I simply did in 2 layers and clued them together afterwards.
    So
    So that worked out nicely and this is how it disassembles:
    From that point I started to try out how the packaging would work out.After some fiddling I got this:
    Quite nice so far, but clearly some drawbacks:
    - the box is a lot higher than needed, but that was a bit of a given, since I used the parts of a stool to build the small site sf the box.
    - the plates to sit from the stools a just a tiny bit to big in diameter to fit 3 of them in one layer.
    But not too bad for the first shot.
