The Digispark is a cheap and easy board to build USB devices, but the original circuit suffers from some unlucky design choices:
- The fist one is the LED connected from the pin P1 to the ground (through a resistor, of couse) which bias this pin to ground.
- The second is that the header with I/O pins does not contain a GND pin (neither a VCC line)
- The third one is present on the chinese clones. The pin 5 not programmed as an I/O line but as a RESET pin.
The three issues above makes the life harder when you aim for a minimalist design like in the present project, but let's pour the cards on the table:
As for the resources:
- We have three I/O pins available
And the limitations
- One of the I/O pins is biased to the ground
- No GND at I/O header
Now the demands for this project
- Four keys that might be used in combination (diagonals)
- A potentiometer for selecting sensitivity
- Minimum extra parts involved
- Shall be attached only to the I/O header
Easy Peasy!!
