The first thing that came to my mind to add a slider was to use a potentiometer in series with a 1K resistor.
Then I remembered that the ground is not available at the I/O header.....
This is bad... very bad.... It leaves me with only two options.
- Add the GND using a wire
- Use the RESET pin
- Hey, there is a third option here! dont't ya think this project has already many buttons? use them smartly!!!
