Maker Muscle Durability Test Rig
03/18/2018 at 01:43 • 0 commentsThis last week, I've been finalizing the drive nut design made with Igus 3D printed high performance plastic (https://www.igus.com/3d-print-material/3d-print-material) so I setup a quick test rig using the Maker Muscle Stepper Driver Breakout board (coming soon to https://deezshop.com/) with a Teensy 3.2 (https://www.pjrc.com/store/teensy32.html) and super robust SureStepper SD6128 driver from Panucatt devices (http://www.panucatt.com/product_p/sd6128.htm) to move the Make Muscle back and forth while storing a counter.
As of this writing, the counter has more than 50,000 strokes...and it's still going perfectly. I'll be taking it apart soon to see the wear on the nut.
A little fun at Comic-Con San Diego 2017
07/29/2017 at 22:33 • 0 commentsCheck out the full story on this at Kickstarter. Here's a funky short video on the Maker Muscle Wings "Evolved" version I show off at Comic-Con last week.
Drive Nut design for injection molding
07/17/2017 at 19:37 • 0 commentsHere's some progress on the drive nut that's going to be made with injection molding process in solid Dupont Delrin (AKA acetal) plastic material. This will give the drive nut good strength and a more wear resistance.
Injection molding filling heat simulation to visualize the flow of the plastic timing.
Mock up mold structure for v5 of the design.
1 day left on Kickstarter!
06/20/2017 at 22:11 • 0 commentsOnly a few hours left on the Kickstarter campaign, so If you want to get in on the deals, there's only 1 day left and we are at 96%. Help us meet the goal and fund this project. I have the original 3D scanner robot in the works that was the inspiration of the Maker Muscle, and if it gets funded by tomorrow, it'll be done better and much faster! Help spread the word on the last hours of the Maker Muscle Kickstarter. Thanks!
https://www.kickstarter.com/projects/deezmaker/maker-muscle-worlds-first-customizable-actuator-fo
Picture below is the current progress on the 3D scanner using the Maker Muscle. It's going to be telescoping and much lighter the my previous iteration. Still a few more pieces to design, but it's coming out nice.
Maker Muscle + Mechaduino with Bluetooth & Sensor
06/17/2017 at 22:27 • 0 commentsPosted a quick video showing how the Maker Muscle can be used with the Mechaduino, Bluetooth and Sensor.
This video shows how bluetooth and a distance sensor works with the Maker Muscle actuator.
Links to the items used for this video:
Maker Muscle Actuator: http://MakerMuscle.com
Maker Muscle Kickstarter Project: http://kck.st/2rx5c0z
Mechaduino Controller: https://hackaday.io/project/11224-mechaduino
Distance sensor VL6180X from Adafruit: http://amzn.to/2sqVgcK
Bluetooth Module HC-06: http://amzn.to/2sraOxd
MIT Andriod App Inventor: http://ai2.appinventor.mit.edu/
MIT App used in video: ai2.appinventor.mit.edu/?galleryId=4969190983991296
Mechaduino Firmware Demo with Bluetooth and Sensor controls: https://github.com/Deezmaker/Mechaduino_BT_Sensor_Demo
Cosplay wings with Maker Muscle
06/04/2017 at 09:47 • 0 commentsHere's a little more details on the cosplay wings I made to demo the Maker Muscle at the Maker Faire Bay Area 2017.
Kickstarter Launched!
05/20/2017 at 09:23 • 0 comments -
LAUNCH DATE IS SET!
05/16/2017 at 01:55 • 0 comments -
First batch in. Ready for Kickstarter launch soon.
05/10/2017 at 00:43 • 0 commentsFirst batch of aluminum is picked up. Here's a picture of the die that made them.
It's now at the anodizer getting ready for some color...
Progress on a demo build for the Maker Faire
05/07/2017 at 05:09 • 0 commentsMaking some cool progress on a demo build using the Maker Muscle. Getting ready for the Bay Area Maker Faire.
